doing an FEA analysis
  • Thread starter Thread starter domslude
  • Start date Start date
D
domslude
Guest
Hello all,
I'm new to Pro E wildfire as well as it's ability to use Mechanica as well. basically I have a simple differential mount and I need to do an quick fea on it. I'm trying to do it, but it will not work, somehting about the shell pair will not work. Any ideas? I have uploaded the small pic so someone knows it well could help me out. Thanks
Dom
2005-04-27_005645_diff_mount_65mm.prt.zip
I couldnt open the file you attached.why did you need to use shell models? if you have to , go and read some important points of creating shells in the user's manual. You probably have problems with meshing...?
