DOF Springs???
legersalazar
Aerospace
CA
Hello Forum,
I've been reading about modeling fasteners on the web and all sources suggest to use "spring/damper" elements (CBUSH) in lieu of DOF Springs.
My question to you is:
What are "DOF springs" used for???
Thank you,
Whyowhyowhy
providing a elastic connection between pieces, like rivets.
@rb1957
Aren't "Spring/Damper" elements (CBUSH) preferred for any type of fasteners (including rivets)?
CBUSH = dof spring ... CBUSH is the NASTRAN element (used to be CELAS), "dof spring" is FeMap modelling
I'm working with FEMAP Version 10.2.1A (preprocessor) and NX Nastran (solver) and it's telling me that my "DOF Springs" are CELAS, not CBUSH.
does it matter ? if the data input for your dof spring is a single stiffness in a specific direction, then it's a CELAS. if the input is more generalised (mulitple stiffnesses, rotational stiffness, damping, ...) then that sounds like a CBUSH. looking at the f06 or your user manual should tell you the specific element used in analysis.
looking at the data entry i have (FeMap 10.3), "dof spring" has a single stiffness (= CELAS) and "spring/damper" multiple (= CBUSH).
look at the f06 to be sure.
I've noticed a difference in results obtained when using a CBUSH element vs using multiple CELAS elements to simulate a fastener with tension/shear capabilities.
Why and how is this different?
Thank you,
Whyowhy
