bojoka4052
- Oct 8, 2021
- 108
According to Eurocode 2, the characteristic yield strength of steel reinforcement (fyk) should be within the range from 400 MPA to 600 MPA. I believe the Young Modulus is usually around 200 GPa for steel.
Does these two material properties affect the buckling of a column subjected to a compressive load?
