Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
W8x10 and W10x12 are almost always very short, so little of the cost is from tonnage. The weight difference is small between those and W12x14, which almost never causes any connection difficulty.You should definitely specify in your Agreement if you won't be designing the connections.
I like to design the connections, or at a minimum make sure a reasonable connection should work for the member sizes shown on the plans. For example, with really shallow I-beams (like W8s and W10s) it's not uncommon that a basic shear tab connection with (2) bolts won't work. I'd rather know that up-front so I can either choose a deeper beam section (if possible) or a different connection type, rather than wait for the steel fabricator to (hopefully) catch it.
I'd also add that I've seen a very wide range recently in terms of the quality of work done by steel detailers and fabricators. It makes me more cautious when it comes to handing off this very important part of the design.
The W8s and W10s I mention are common in residential construction where a shallow beam is needed to fit in a limited floor depth. Without such a constraint, I normally use the deepest section possible.Knowing what I know now, I would almost never use a W8 and might even use W12x14 as the typical minimum.
