DMM Accuracy Spec- How to Interpret? 1
dnrepair
Automotive
How does one interpret the accuracy specification on a DMM.
In this case a 3 1/2 digit LCD display, 2000 count meter.
For example, under DC volts the following is shown for the 20 Volt Range:
+/- 0.8% of reading + 5 digits.
Range: 20.00V
Resolution: 10mV
Using a 10 VDC reading (as an example), I can see where +/-.8% of reading indicates that the meter can display anywhere between 9.92 -10.08VDC. How does one interpret the + 5 digits?
Thank you
The % of reading is a gain error. The % of FS (or just a number of digits) is the linearity error.
In modern terminology I should be saying "uncertainty" rather than "error"
You are nearly there with your 10V example. The meter might read 10.00V. ±0.8% is ±8 digits and then you have another ±5 digits. Result ±13 digits. The "digits" refer to the least significant digit position of course.
10.00V ± 0.13V.
Thanks. Is it correct then, in the 10V example, that the meter could display a reading anywhere from 9.87V to 10.13VDC. In effect an accuracy of 1.3%?
Or, in a different example, say the actual measured voltage is an automobile battery at 12.60VDC. The meter could display a reading anywhere from between 12.45 to 12.75VDC?
12.60V x .8% =.10 (12.6-.10) = 12.50
12.50-(5 digits)= 12.45
12.60V x .8% =.10 (12.6 +.10)= 12.70
12.70+(5 digits)= 12.75
Is this correct?
Thanks again
Yes. Top marks on your results.
This maths looks a bit dodgy though ...
Looks like a cut and paste error.
I would have gone
12.60 + 0.8% = 12.6*(1.008) = 12.70
12.60 - 0.8% = 12.6*(0.992) = 12.50
Fluke has some really good application notes on DMM's, you can go to this link,
and select the note for "Understanding DMM Specifications", does a great job explaining accuracy and uncertainty specifications.
We use a lot of these notes for technician training, as the info is pretty general in nature and most times applies to other makes of DMM's.
Hope that helps.
Thanks. Excellent explanation in 'Understanding DMM Specifications". I had searched on the Internet and could not find anything to the subject. This is great and what a great resource the applications notes are!
