Diverter valve question - Vendor or valve alternatives?
hollerg
Chemical
Mar 22, 1999
97
Who makes an inflatable seal tubular diverter valve for solids handling. So far I have only been able to find Zeppelin, a German Mfg co. Any USA companies a little closer?
As an alternative are there any multiport ball valves that might work? Cycling is only 1/month. T= 200 F max. Pr nomrally 6 psi 30 psi water used for cleaning. Cleaning washes out a solids buildup from dilute phase conveying.
Although the valve will not be actuated while water is under pressure, some salt water will get behind a ball and dry out. The concern is solids forming from evaporation, or powder that would work behind the ball, might seize it or score the seat/sealing surface when actuated the next time.
Salina Vortex make the industry standard for dilute-phase conveying diverter valves.
(From Memory, and it's been a while): They don't use a ball, it's a rotary cylinder.
Unfortunetely Salina does not make an inflatable seat version. They do not want to quote on this application
As diverter valves for special applications are difficult to find on the market, you might come better out looking for a combination of single valves.
What about knife-gate valves?
I was trying to have a cavity and deadleg free a path so that as much of the water used for cleaning would be blown from the piping for rapid restart of the process. The product is a salt which would adhere at the point of moisture.
So is this feasible with knifegates? I imagine it takes some sort of flush plate design and a special wye type fitting. The line is 4" round tubing 11 ga, although I could transition to square, if necessary.
Contact me, maybe I can help.
I am currently making one for a major US oilfield co.
mohrfeld@premiumvalves.com
2 posi-flate butterfly valves on a tee, if you really, really MUST have the inflatable seals.
