If i have to transmit an equivalent load(moment+force) from a reference node to the nodes of a half circular surface.(outer ring 480 mm, inner ring 435 mm), should this reference node be at the centroid of the surface?? and is it necessary to use a cylindrical Coordinate system for coupling?
