Last time I needed a criteria for max distortion was for a banana-warped pipe due to olet welding.
Neither any of the ASME codes, ASTM specs (it was an A312 TP 304 pipe), PFI, PIP or even the EN 13480 (European design code for process piping which, at some points, is less rudimentary and more straightforward than B31.3) not had any criteria for my problem.
I ended up determining my own set of criteria.
From what Ive read, your distortion might not have been documented (afaik) in any standard, or Im misinterpreting your problem.
Good luck. Anyway, PFI ES-3 is a nice standard. Though PFI standards maybe expensive, some of them provide good guidance on all day fabrication aspects (i.e. problems) for piping.
