Hello what is rule of the thumb to have distance of the clips on trim panels between each clip and from the edge of the panel? On some cars order of fixing elements is good and you can remove panel only with usage of plastic trim panel tool to disassemble panel, but somewhere I notice that clips are in not correct order and they are far from edge of the panel so you can remove those panels by sticking finger between panels and remove them.
Here is example on which panels I am asking:
Usually plastic arrow clip can withstand around 30N of pulling force, does anyone knows what force is necessary to remove panel by hand and by trim panel removal tool?
