Displaying dimensions as pararmetric equations
Prospero999
New member
Dec 20, 2009
20
Hi all,
Can some kind chap tell me how to get ST1 to display dimensions as pararmetric equations (like d3=89.5) (i.e. like in Autodesk MD)?
Many thanks,
Anthony
Hi Anthony,
RMB on the dimension and you should see Show All Values, Show All Names, and Show All Formulae.
Works in models and in draft.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Hi Beachcomber,
Couple of probs I'm having:
1) I don't seem to be able to enter the v numbers into a new dimension - ST1 says it doesn't like the format... so I can't just put in V31 for example.
2) Extrusions, for example, seem to be given long names rather than v numbers...?
Cheers!
Anthony
You can't enter the name of the dimensions directly in the value box. If you double click on the dimension you should then be able to enter an equation. The equation can be only the name of another dimension.
You can also acces all this through the variables tables, then you need only to click on the according dimensions instead of typing the name.
Hope it helps
Patrick
I think you are trying to display name and value but this is not one of the options available.
You can display either but not not both.
Maybe an enhancement request is required.
bc.
Quadro FX4600.
