Hi All,
I'm editing drawing templates... ( Yes, ...)
Since we run in "managed mode" almost all the text in the drawing heads are mapped to an attribute, similar to <W@DB_PART_NAME> and when the template is used it will display the Part name, " abcd1234" or whatever.
Now I need to verify templates which i have received and should be imported into Teamcenter, and then the attribute mapping needs to be correct.
Thereby i either need to do Information - Object on each text and in the listing window find the mapped attribute, or double click the text and read the string in the note editor. Neither method gives an overview when there are a number of texts to check.
Is it possible, with the help of VB or similar "print"/ "display" the "<W@attribute>" next to the text object ?
( Yes i know, i need to learn some programming...)
We run NX7.5 at the moment.
Tomas
Tomas
