Dispersion Wall 1
kkoloj
Can anyone provide me with a reference for dispersion walls, which take concentrated flow and converts it to sheet flow.
I have also heard these referred to as "level spreaders". Don't know of any real references, but it might help in your search.
Lots of cities and states have specifications or design minima in their drainage ordinances.
Level spreaders work best on slopes flatter than 10% with flows less than 30 cfs. Level spreaders should not be constructed in fill slopes. Some agencies will let you get away with a non-erosive velocity passing over the level spreader lip. Others take a more conservative view. (Briefly, flow reconcentrates within a distance, L, of the level spreader, where L is a function of the slope. Some agencies require a flow depth over the level spreader that results in a non-erosive velocity at a distance L/3(?) downstream of the level spreader where the flow has started to reconcentrate.)
