Discharge pressure on submersible pump.
Ork1
Mining
I am troubleshooting pump performance on a 58hp submersible Flygt pump. I want to install a pressure gage on the discharge pipe. The discharge pipe is Goodall hose connected to a check valve (4") then to hard pipe.
Question: where is the best place to install a pressure gage?
should I drill and tap into the check valve itself?
Pressure gauge before the check valve (immediately after pump discharge, wherever possible) gives you the pressure drop across the check valve as well.
PS: We have a Pump Engineering forum for pump related issues.
