CivEnvEng98
Hello all,
Looking for insight into what technologies are being used for treating the waste streem of a sodium hypochlorite facility.
Here is the characterization:
21,000 gpd
14,100 lbs/day of Sodium Chloride
233 lbs/day of Sodium Chlorate
341 lbs/day of Sodium Sulfate
445 lbs/day of Calcium Chloride
0.12 lbs/day of Silicone Dioxide
The receiving WWTF is only at 2.4 MGD +/- so this waste stream would have a significant and negative biological impact and we must find a way to lower sodium and chloride levels.
Dilution you say? Try 11 + MGD of local well water to dilute to the Utility's request of 250 mg/L of chlorides at the point of entry to the sewer collection system. No can do.
We belive the only solution is to 1) incinerate the waste stream or 2) create a filter cake for ultimate disposal at a local landfill or one that accepts haz materails, if needed.
I know of zero discharge facilities, but haven't been told yet whether or not this facility will go that route.
We have a few options in mind, but would like to see what ideas you all can come up with.
Any help would be appreciated!
21,000 gpd
