That particular "gas stream" appears low corrosive ... Unless it ever gets wet, or has any water vapor contamination or any chance of sulfer and water vapor. Then, corrosion problems and mitigation (thicker walls, stainless steel has to be used, wall contamination and deposits and sludge/munge/corrosion residue) will dominate the heat transfer benefits of copper.
Too bad you can't use silver. 8<)
