directory printer
WaterGIS
Geotechnical
JO
I’m looking for excel sheet that work as directory printer, to print the all the file name, type and other properties in an excel sheet
Best regards,
Hi WaterGIS:
If you are using EXCEL, the following macro will print the names of all the sheets in your workbook (starting from cell A1 down) ...
Sub y_1()
'Macro 1/28/2007 by Yogi Anand
For i = 1 To ThisWorkbook.Sheets.Count
Cells(i, 1) = Sheets(i).Name
Next i
End Sub
I realize that you want to print more than just the names of the sheets in a workbook, but this should get you started.
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
thanks alot
but what i was lookg for is printing the files properties in the folder
best
You can always "dump" a directory echo into a text file from the DOS prompt:
DOS> DIR E >FILE.TXT
Then, open it in Excel... That's one way of doing it.
I suppose that the proper command line is
[tt]DIR > FILE.TXT[/TT] (without the E)
Cheers,
Joerd
harumph!
"DOS>" was meant to be the DOS prompt, nyaah.
Sorry to have offended you, I was referring to the E after the DIR statement.
Cheers,
Joerd
thanks for all
your notes were very helpful
thanks
