Hi All,
I have a question about direct (+/-) tolerancing and its interpretation (ASME Y14.5-2009). The basic question can be phrased as:
Does direct tolerancing on 2 planes mean that every point on the 2 surfaces must lie within the specified perpendicular distance from each other or only that every point on one surface must lie within the specified tolerance from its counter point along the axis of measure?
I have always been of the belief that it is the former and my reasoning for this follows, but I cannot find the section in the standard that states this completely (other than rule 1).
Attached is a quick sketch showing the problem in its simplest form with a +/- tolerance on the length of a shaft. Given the drawing with case 1 dimension scheme, my interpretation for the functional limits of the part is:
1. The outer diameter establishes a datum axis.
2. The perpendicularity callout establishes a .002 wide tolerance zone perfectly perpendicular to the datum axis A that every point on the surface must lie within.
3. According to Rule 1, all the points on the face of the opposite surface must lie within the maximum envelope established by perfect form at MMC.
4. All the points on the second surface must also lie within a minimum envelope established by perfect form at LMC?
The two drawings for case 1 show a set of simple deviation possibilities.
In the first drawing I am of the mind that the surfaces have deviated as much as possible to still generate an allowable part; if any part of the second face extended past the maximum zone or did not reach the minimum zone this part would be out of specification correct?
For the second drawing, although every set of points on the faces lie within the direct limits of measure from each other along the axis of measure, some points on the face exceed the perfect form at MMC envelope established by rule 1 so this part is definitely out of specification correct?
Finally we come to measurement. Suppose we have a part that is produced like the section drawing in the second attachment. Assuming my interpretation was correct, this part is out of specification and should be rejected. If it is measured with a caliper or surface plate and height gauge as the only measurement, it could be accepted. Measurement by CMM and taking the distance between points along the axis, or measurement on the caliper and surface plate combined with a measure of the flatness of each face would be the accurate way to measure and detect non-conformance in this manner; correct?
