Fitting a commutation diode across the soleniod will slow the release time of the soleniod when switched off.
The magnetic field will decay much more slowly than without the diode, the decay of flux will be aproximatly exponential with a time constant of L/R. Note that the vale of L will change as the magnetic circuit varies due to armature position.
I once tried to improve contact life in the fuel pumps of a Jaguar E type with diodes but the delay made the solenoid operated pumps cycle time to long to give good fuel delivery at large (heavy footed) throttle openings. The final cure was an arc suppressor of 10 ohms and 0.01uF in series over the points, just like SU used to fit. An alternative cure would be a voltage dependent resistor or possibly a zenner over the switching device.
