DIN5480 2006 part 14 is in usage or not??. 2
Vaithilingam G
Automotive
Sep 1, 2023
8
thread406-246456
I have seen @gearcutter comment in one thread, @gearcutter claimed DIN 5480-14 is not in use If this is not in use then which standard is referable for Side fit spline tolerances??.
The DIN 5480-14 is now a part of DIN 5480-1:2006-03.
It's been replaced with DIN 5480-15:2006-03
Vaithilingam G
as stated by Spigor it was superseded. however it can still be purchased for historical review, since there was parts fabricated to this spec. and may still be in service.
Furthermore, the edition DIN 5480-15:2006-03 lists changes made to the DIN 5480-15: 1974-09, and the differences are editorial except for removing two gauge tolerance classes LQ3 and LQ4. So, the 2006 edition has the backward compatibility and replaces the earlier editions, as the probability of ever seeing a reference to these two removed classes is low.
There was a DIN 5480-15 Berichtigung 1 published in 2009:
@Spigor In this latest edition (DIN 5480-15 2009) only 2 pages are there. Only 2 pages will be there??.
@Spigor I don't have that, Can you share If you have full standard.
