DIN Machining Tolerances
abell88
3
Does anyone have any info relating to General machining tolerances to DIN standards. Whether you can point me to the right standard # or simply just share your knowledge????
I have a meterbody I need to machine but alot of the features on this body that are machined are not toleranced...they have dimensions...just no tolerances.
Thank you
ISO 2768 is one standard you might look to.
But it wouldn't apply unless called out on the drawing...is there a spec. called out on the print, or a block or not defining general tolerances?
