I've been working with ISO tolerances for a while and have been puzzled by this. Are the classes used for splines the same as for general holes and shafts even though the nomenclature is reversed?
A typical call out for a shaft could be 150f8. However the tolerance on a spline shaft would be 8f. Is this the same system? Or is there a separate system for splines. Metric threads reverse the letter/number arrangement also. Can anyone tell me why?
