DIN 5480 spline maximum torque ?
hansonbrest
Industrial
Oct 14, 2003
17
i have a 50 kw hydraulic motor , driving at 300 RPM ( 1500 N/m torque )
i want to check that a DIN 5480 spline 40 - 3 - 12 - 9H
can transmit that torque , spline length is 40 mm
i am machining a shaft from 4340 steel , no heat treatment after machining , the splined part is the smallest diameter ( weakest link )
the shaft is very short
someone got numbers i can check for that spline please ?
thankyou kindly
thanks but this is involuted spline
4340 tensile 1100 Mpa
You can use that document for a ballpark value. If you need the exact number, then you should obtain this standard:
DIN 5466-2 Splined joints, calculation of load capacity - Part 2 Splined joints according to DIN 5480
