DimXpert from part to drawing 1
adampunch
71
Usually at work the same engineer both models a part and then details it straight away. But sometimes there's a few days between, or the detailing is left to a different engineer or drafter. So i have been trying to use some dim Xpert dimensions in my parts to call attention to important tolerances. Then from the drawing i try to import the model items, but no tolerances get carried over with the dimensions. Is there a way to carry over the tolerances, or do i just have to look at the model anyway?
SW 2008 Office Professional SP 4.0
Intel Xeon 3.40GHz
3 GB RAM
Windows XP SP 2
I don't use the DimXpert. I apply the tolerances to the regular dimensions, and they are inserted via the Model Items.
[cheers]
Thanks again, CBL. Although this begs the question, what use does dimXpert have?
Intel Xeon 3.40GHz
3 GB RAM
Windows XP SP 3
You may have to adjust a couple of settings to get the DimXpert dims with tolerance to show.
Check the SW Help > Index for DimXpert for parts, import dimensions into drawings[/quote].
[cheers]
