Dimple Jacket Hydrotest Pressure
MechD
KE
Hi all,
I am currently struggling to agree with our Third Party Inspector on dimple jacket hydrotest requirements per ASME VIII, Div 1. I have always treated dimple jacket welded onto a pressure vessel as it's own unit, rather than another vessel chamber and / or combination unit. (For example, vessel -1 to +3 Bar, dimple jacket -1 to +8 Bar)
For this reason, we would test the vessel to 1.5 times vessel design pressure (4.5 Bar), and the dimple jacket to 1.5 times jacket design pressure (12 Bar). We would not usually allow for the max. differential pressure between vessel and dimple jacket, as would be the case with a conventional jacket (1.5 x 9 = 13.5 Bar). In essence, a pressure vessel put into atm conditions is not designed for FV just because the dimple is rated for FV. Instead, a proof test is completed on a sample piece of dimple as per Appendix 17 to verify backing plate thickness, dimple design & fabrication.
Third Party believes that the vessel shell i.e. any interface which could be subjected to max. differential pressure has to be designed & therefore hydrotested to 1.5 times this potential pressure. I would agree if we were using conventional jacket or if this were separate chambers of a pressure vessel. However I was under the impression that dimple / embossed assemblies are considered a stayed surface, thereby acting as a stiffener to the vessel walls, rather than applying additional pressure to it. Even referring to ASME VIII, Div. 1, I seem to find more grey areas & more questions rather than solid definitions. The bone of contention is UG-21 which states that the vessel must be designed for worst case of temperature & pressure & loadings.
So referring to UG-99 for hydrostatic tests, combination units are explained in UG-19 (a). This section advises the user to refer to Appendix 9 for jacketed vessels, which is the case in my vessel. However App. 9 explicitly states it DOES NOT apply to dimpled / embossed assemblies. Instead you are directed to UW-19 Stayed Surface Construction. This section advises dimensional requirements & proof test requirements but no specific hydrotest for the duplicate parts built to the same dimensions as the proof test. Instead the user is advised to refer to UG-99 for any duplicate parts... which brings me back to the original question - Is dimple jacket regarded as a separate chamber i.e. combination unit? If so we have been under hydrotesting for many years. My third party inspector keeps bringing it back to the basics of a flat plate with FV one side and 8 bar on the other side, so logically the flat plate should be designed & tested for 9 Bar. I can understand this train of thought in theory, but I was under the impression that a stayed surface was not regarded as another vessel chamber in this way. I guess I would like to know if other people are hydrotesting their dimple jackets to 1.5 times Design pressure, or 1.5 times Max. Differential pressure. I would appreciate some insight or feedback from someone with more experience in the field, not only to resolve the current issue but also to ensure adequate design & testing of future vessels.
Thanks,
MechD
MechD, can you not designate it as a differential pressure design, such pressure as is suitable to your hydrotest?
Mike
While the design accounts for the diffental pressure acting between the two chambers I do not believe it needs to be tested to the higher pressure. I would argue that you should test at 1.5 x design...not 1.5 x diff. The differental pressure only exists in a vacuum case and if you test at that level you may have a failure in the dimple due to the extra force acting on it...maybe it yields or over inflates or something. We have always hydro tested and designed as seperate chamber but the design is by proof and not app. 9 as you stated above.
Apologies Mike, I don't fully understand your question. I'm trying to work out if I should be hydrotesting the dimple jacket to 1.5 times Jacket Design Pressure or 1.5 times Max. Differential Pressure. Are you saying I should be hydrotesting to 1.5 times Max. Differential pressure? i.e. 1.5 x (Max. Jacket Design Pressure + Full Vac in the vessel)?
The confusion came up because he interprets dimple jacket as a combination unit, whereas I do not.
Thanks,
MechD
MechD, I haven't really puzzled out your exact design conditions and hydro pressure combinations, but what I am saying is you limit, as stated design conditions, the allowable differential pressure applied to the jacket and/or vessel to be the jacket and/or vessel design pressure, or such other pressure that yields the hydro test pressures you want to use. Then, as long as the vessel / jacket is operated within these differentials all is well.
Mike
OK I get you this time! So if my Jacket Design pressure was originally 8 Bar but my vessel could operate at -1, you're suggesting I could just drop the Jacket Design pressure to 7 Bar so that the max. differential falls within the original 8 Bar designed for.
So you feel that, even in the case of dimple jacket, we DO need to allow for max. differential pressure between vessel & jacket and have to carry out hydrotest based on this max. value. This is in line with the AI's opinion. But innovation2 is thinking we should calculate as I did. So I guess this just highlights another grey area of code interpretation. It looks like we may have to change our current procedure for calculating hydrotest pressure to avoid any future disputes!
Thanks for the input!
MechD
MechD, I am not suggesting you change any design pressures. You state your vessel design pressure as 8 bar differential. This assumes that it not be operated such that the differential is exceeded, i.e. if the vessel is at -1 the jacket not exceed 7. Vessel at zero, jacket may be at 8. I don't know if this is feasible for your vessel or not.
I am saying set your design pressure at 8 differential so that 8 is your hydro basis, which is what I gather it is now.
Mike
Ah ok sorry, understood now. I don't think we will be allowed do that in this case but it's a good idea to keep in mind for future projects, especially if there was a higher margin between the design pressure & max. differential.
Thanks again,
MechD
Yeah, I'm just saying pencil-whip it if you can:)
Mike
