Dimensions on top of leaders
AUTOMATIONENG
I am using SW2001 plus. When I dimension a horazontal feature in a drawing SW's puts the dimension on top on the leader instead of in the leader. I have changed the setting in the Document Properties Detailing Dimensions but it does not seem to take. Any ideas?
Check the properties on the individual dimensions. Maybe they got hanged from "use document default"
[bat]I may make you feel, but I can't make you think.[bat]
Check the display of the dims like TheTick specified above by RMB the dim\Properties\Display
Just to make sure...You did change the
Tools\Options\Document Settings\Detailing\Dimension\Leaders
to the correct options you want...right?
Scott Baugh, CSWP[wiggle][alien]
3DVision Technologies
faq731-376
When in doubt, always check the help
