Dimensioning
solidhardhead
Is it possible to break a view around a dimension? I tried the "Broken View" command but it does not allow me to hide the break lines.
Sorry, I don't understand the question.
Can you post an image of what you are trying to achieve?
See faq559-1100
[cheers]
Correct me if I am wrong but it sounds like you're trying to trim the break lines to the edge of the part?
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
CorBlimeyLimey,
I am blocked from all 4 of the listed sites.
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
Go to Tools > Options > Detail see the Break line extensions setting.
Heckler
o
_`\(,_
(_)/ (_)
Set that to Zero and it will eliminate the breakline extending past the part line.
Heckler
o
_`\(,_
(_)/ (_)
Bradley .... That must be your IT peoples doing. Can you access them from home?
[cheers]
CorBlimeyLimey,
Yes it is our IT. I can see it from home.
Bradley
But how do I eliminate the break line all together? I just want to break the part lines without leaving any other lines. Very similar to how to looks when you break dimension lines around one another.
I think I understand what you're wanting. You want to have a "gap" in the object line (part edge) for the dimension's witness line to pass through. I don't think you can do that. I'm not too familiar with dimensioning standards, but I doubt that would be acceptable under any of the "standard" standards.
I would just change the line type of the breakline so it appears to be a part line. Anything more than that I think you're asking for something that is not "standard" in drawing practices.
Heckler
o
_`\(,_
(_)/ (_)
