Dimension to Intersection
penguin221
Industrial
Does anyone know how to create a dimension in the drawing mode that will go from on intersection of two lines to another intersection of two lines?
Stephen Getsy
Product Development Engineer
Silgan Plastics
You could create a point at the intersections and dimension to these new points. Control select the intersecting lines and add your points.
That works. I didn't know how to get a point at the intersection, but the Ctrl suggestion works great.
Thanks.
Stephen Getsy
Silgan Plastics
Look up the help on "virtual sharps". It's a standard feature - been there forever and it works great. You can even select the type of display for the virtual sharp point.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
As a slight aside, I have tried to use virtual sharps on a part similar to a styrofoam cup but having a large radius at the bottom.
While dimensioning the sketch revolution profile I was unable to find 'virtual sharps' at the bottom external corner of the bottom radius.
I'm probably missing something, as this should be a 'can do'. Help??
You probably have to add teh Virtual Sharps manually. Just CTRL-select the tangent lines to your radius, and click on the Sketch Point tool to add one.
MadMango
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read faq731-376 to make the best use of Eng-Tips Forums?
MadMango is right - because there really is no intersection out there that is can recognize.
