Being new to solid works, I understand that I will have some problems.When I draw a sheetmetal part , sort of like a channel, using alibre all I have to do is double click on the dimensions and a box appears so that I can change them. Solid works works at this sometimes, and not others, when I click on a dim, a dimension properties box appears.Then I can not edit the dimension. What am I doing wrong? thanks
