Dimension Lines 1
geo12
CA
I am enquiring about the dimension lines in SE 14.
Can anybody help me. How to create the dimension lines offset like a funnel while it is in stack up type from a common datum and the lines are too close.
Thanks in advance.
From Solid Edge Help:
Placing Coordinate Dimensions with Jogs:
To add one or more jogs while placing a coordinate dimension, first select the element you want to dimension, then hold the ALT key and click to add the jogs.
Adding Jogs to Coordinate Dimensions:
To add a jog to an existing coordinate dimension, use the Select Tool to select a coordinate dimension,Position the cursor over the dimension line where you want to insert the jog, Hold the ALT key and Click
Thanks Edgeomatic,
Is there a way to modify the default settings for dimensions like prefix zero for dimensions,fonts,etc...
Thanks once again
To set defaults, it's best to open your normal drafting template file and add or modify dimension styles.
You can do this by selecting "Styles" from the "Format" pulldown. Choose "Dimension" from the "Style type" drop list. from there you can add or modify dimension styles to suit your needs.
Thanks Edgeomatic.
It works
