Dimension Line value disply 3
CAD2015
Automotive
I'd like to have the value of both horizontal and vertical dimensions in the middle of the dimension line (the way they are shown in the attachment)m but with one adjustment:
I want the dimension line interrupted on the area where the value is located.
How should I get that?
MZ7DYJ
Change the drafting standard to ANSI or ASME when you create new drawings.
For exisiting drawings; select all dimensions and change standard or ANSI or ASME
check your drafting standard (XML file)
Eric N.
Thank you both!
MZ7DYJ
If you want to do this in a CATScript...
Code:
Sub CATMain()
   ' Variables declaration
    Dim oDrwDocument As DrawingDocument
    Dim oDrwSheets As DrawingSheets
    Dim oDrwSheet As DrawingSheet
    Dim oDrwView As DrawingView
    Dim oDrwTables As DrawingTables
    Dim oDrwTable As DrawingTable
 Set oDrwDocument = CATIA.ActiveDocument
    ' Set the drawing document standard
CATIA.DisplayFileAlerts = False
	Dim Message, Style, Title, Response, MyString
	Message = ("This macro will change the drawing standard according to what user will choose"  &_
			(chr(13)) &_
			 "	- The active document must be a CATDrawing (local or VPM)"&_
                         (chr(13)) &_
			 "	- Drawing size will go automatically to the biggest standard format"&_
			 (chr(13)) &_
			   ""&(chr(13))&_
"	Do you want to continue ?")
	Style = vbYesNo + vbDefaultButton2    'Define buttons.
	Title = "Purpose "
	Response = MsgBox(Message, Style, Title)
		If Response = vbYes Then    ' User chose Yes.
Dim myStringcase 'As Double
myStringcase = "1"
myStringcase = InputBox ("Please enter the case" & chr(13) & "1 for ISO"  & chr(13) & "2 for ANSI"  & chr(13) & "3 for JIS" , "Standard case" , myStringcase)
If myStringcase = 1 Then
    oDrwDocument.Standard = catISO
ElseIf myStringcase = 2 Then
    oDrwDocument.Standard = catANSI
ElseIf myStringcase = 3 Then
    oDrwDocument.Standard = catJIS
Else
	End If
    '~ Bellow code will work only for ISO standard, if you want to set the size for other standards you need corect name, like catPaperA3
    '~ Uncomment to make it work
    '~ ' Retrieve the drawing document's sheets collection
    '~ Set oDrwSheets = oDrwDocument.Sheets
    '~ ' Retrieve the active sheet
    '~ Set oDrwSheet = oDrwSheets.ActiveSheet
    '~ ' Set the sheet properties
    '~ oDrwSheet.PaperSize = catPaperA3
    '~ oDrwSheet.Orientation = catPaperLandscape
    '~ oDrwSheet.Scale2 = 1
CATIA.ActiveDocument.Update
End If
Fernando
