H
hellomoto
Guest
Almost all molded plastic parts have drafts. Any comments on what the best practice is for dimensioning features with drafts?
Let's use a simplified example for the discussion:
A machined circular boss (O.D. +/-.003) on a plate has hard edges. Drawing show dimension from diameter edge of circle to one of the four edges of plate (+/-.010). Inspector can use calipers or video inspection or etc. to inspect the dimension: Easy.
A molded plate with a circular boss requires the boss to be drafted 1 deg and a R.01" fillet at the base and a R.005" rounded edge at the peak. Inspection not so easy. (e.g. Inspector with video inspection system may not be able to find hard edges, use of calipers would also be challenging due to the draft on the boss)
What would be the best way to dimension the boss location to the edge such that it can be inspected? (and what would the inspection method be?)
