Dimension colour
Simon205
151
Digging up the past a bit, but this is a really simple thing I've been trying to do for ages:
Changing the dimension colour on all drawings (when changing just the settings in Tools > Options > System Options > Colors doesn't seem to work) - what you have to do is activate your 'line format' toolbar, and click the RH most option on, called 'color display mode'.
Or you could move the dimensions onto a layer with an assigned colour.
I am sure if you had called your Tech support person they could have told you that, if they couldn't then your support group is not very good at their job. I would have told you that little trick.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
