Dimension Color
Dman5
Automotive
Mar 9, 2011
36
When I dimension a part the dimension is grey in color. For presentation purposes I will need these dimensions to be black in color. Is there a way to accomplish this? Thanks in advance
Go to Tools > Options > System Options > Colors --- Color Scheme Settings --- Dimensions, Non-Imported (Driven) and change the assigned colour.
Tools> Options> Colors
Change "Dimensions, Non Imported (Driving)" to Black.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
Dman5,
I am going to guess that these dimensions are on a drawing and you are manually adding them as if you were coming from ACAD. If so then you might want to consider using Insert -> Model Items. This is a HUGE time saver in more ways than one.
- - -Updraft
