cmarinelli
While we all love the automatic insertion of dimensions from the model into the drawing, has anyone found an automatic way to attach the end of the dimension line to the end a hole's centerline? SW does not seem to do this unless you make a new dimension and select the hole's centerline. I find it annoying to have to manually move the dimension's endpoint to the edge of the centerline and create an offset by eye.
Dimensions also don't attach to a tangent edge. Here's an example: if you extrude a cylinder, then extrude a hole on one face and dimension the hole to the outside of the cylinder. When you make a drawing, the dimension doesn't attach to the tangent edge.
Anybody have an easy way to handle these?
Thanks in advance,
Chris Marinelli
Dynatech Engineering
Thanks in advance,
Chris Marinelli
