Dimarc
Robert000
45
Hi all,
My problem is in Acad 2007 that the angular dimension
doesn´t work properly. The dimension lenght is paralel
to the object, but is shorter (osnap points are ok). And I don´t need a halfcircle before the value.
How is it possible to solve this problem?
Thanks a lot,
Robert
I do not understand the first problem. Can you attach a screenshot?
2nd: DIMARCSYM
Lothar
ADT 2004
I'm still not sure if I understand what it is you are trying to fix. Can you try to explain again, in a different way?
I think the positions of the arrows are not right.
The dim of the angle is right...
L.
ADT 2004
I have attached another screenshot.
If I am using a _dimangular it is possible
to draw continous dimensions, without interruption.
In case of _dimarc the ending of continous dimensions
are not on the same place as in case of _dimangular.
On the picture, the first dim line is with _dimangular,
the second with _dimarc.
I wold like to create a dimension style which looks like
_dimangular, but the value is the line lenght, not an angle.
Thanks a lot,
Robert
 http://files.engineering.com/getfile.aspx?folder=59dd3d9d-8750-44fa-a1eb-0731a83723f2&file=picture2.JPG
Here is a very crude example of one way of doing this. Your current units (DDUNITS) determine the style and precision of the arc length.
(DEFUN C:DV2 (/ p1 p2 p3 p4 om ang rad arc ark) ; Dimension verts / along any circle
(SetVar "CMDECHO" 0)
(Setq om (GetVar "OSMODE"))
(COMMAND "Osnap" "END")
(setq p1 (getpoint "\nSnap to first point (must be on the arc also): "))
(setq p2 (getpoint "\nSnap to second point (does not have to be on the arc): "))
(COMMAND "Osnap" "CEN")
(setq p4 (getpoint "\nPick a point on the connecting arc: "))
(COMMAND "Osnap" "NON")
(setq p3 (getpoint "\nPoint to dimension location: ")
ang ( - (angle p4 p1) (angle p4 p2))
rad ( distance p4 p1)
arc ( abs (* rad ang ))
ark (rtos arc)
(COMMAND "DIM1" "ANG" "" P4 P1 P2 P3 ARK P3)
(COMMAND "DIM1" "HOM" "L" "")
(COMMAND "DIM1" "TE" "L" PAUSE)
(SetVar "OSMODE" om)
(princ)
After making the dimensions, draw a circle and use Perpendicular Osnap to put all the dimension arcs on the same radius.
