Digitec 8310 x readout & KCI NM701NR1 encoder
rlgauto
Industrial
Can some one point me in the right direction to find information on the Digitec 8310x digital readout and a KCI encoder type NM701NR1, I believe this encoder was manufactured for Kone cranes. I need wiring prints for these two items.
Thanks in advance.
RLGAuto
Tough items to search for! The only thing I came up with so far is:
See pg 84 of the Adobe document, pretty generic wiring diagram of encoder (no color codes on leads).
I am assuming this is an encoder connected to a counting meter-
If the equipment is safely accessible, connected and functional, and someone has electrical knowledge and an oscilloscope or meter, it should be pretty easy to create a schematic from it.
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
analogkid2digitalman
Thanks for your response. These items are not connected together. Not for sure if it is an encoder, resolver or a tach gen. Thats why I started searching for some info.
I do need a diagram for the digital display., I have no other info other than what i have listed.
rlgauto
