Digital Phase Adjuster Circuit
  • Thread starter Thread starter -
  • Start date Start date
Guest
I am currently working on a college project (on PSK)
In order to decode a PSK 'transmission', I need to be able to 'correct' the phase of a squarewave signal(f=4500Hz).
Is there a simple circuit I can use which will vary the phase of such a signal ( 0 - 180 degrees)?
Since you have the waveform in squarewave form, it should be easy to convert to logic level. Then send this to a settable digital delay to adjust the phase.
Ten years ago I programmed a Xilinx Field Programmable Gate Array (FPGA) to variably delay the phase of a 2400 Hz tone 0-180 degrees with 1 degree resolution. Very precise and repeatable. A microcontroller or DSP could do this too, or use a tapped digital delay line.
If you must stay analog, try a Phase Locked Loop (PLL) IC.
Good luck! Kevin VanZuilen "KevinVZ"
