as an absolute minimum, for normal lines (side of the road wooden post kind of lines) i stay at least 10'+. for high tension lines, i stay at least 30'+ away from them and the base of the structure. i will usually opt to not dig under and/or around them at all and i won't put my drillers under them. to be honest, i don't even like walking next to a machine that is simply passing under high tension lines. i may be a chicken, but at least i'm not a fried chicken. moreover, if you've never had a coworker and/or good friend killed because of lack of safety awareness (that could have easily been avoided with a little caution), then i suggest that you reconsider your choices so that you don't have to live with that kind of guilt. i can assure you that the guilt spreads whether you personally had input to the situation or not. i can't imagine the guilt if i'd actually attributed to my friend's death.
