debpriya1984
Geotechnical
- Nov 4, 2008
- 4
“The differential settlement can be computed as the difference in settlement between two adjacent points. It may be estimated as three-quarter (3/4) of the computed maximum total settlement.”
The problem is:
Sometimes we have cut and fill operation and when you have areas of fill we need to estimate de immediate settlement induced by live load (before construction). Long term and settlements after construction could be estimate. Finally, differential settlement could be expected between the cut and fill area…
Some people uses the settlement “after construction” (immediate + total settlement) to estimate the differential settlement!!!
I have used the maximum settlement computed and took ¾ or just the difference between two adjacent points…
I’ve checked this methodology for all sites and the results are satisfactory. Anyway…
what do you think?
The problem is:
what do you think?
