SpringHalo
I'm attempting to make a tank differential system similar to this one and figured out how to get the gear modeling application in NX, and how to work it, but now I'm struggling with the motion simulation. I'm sure the two driving gears are supposed to be revolute, and the outer gear should be revolute jointed to the center, but I can't figure out how to get the pinion gears working so that they:
A. interact with the driving gears (through the gear function)
B. rotate around their own axes while rotating around the outer gear's axis
I'm thinking it has something to do with revolute linking the outer and pinion gears together, but when I do that, the gear function no longer works.
Any insight as to why this is happening is appreciated!
