bornvirgo85
Hello Everyone,
I am modeling cohesive layer(defined as a part) resting on a rigid body. I am trying to give different cohesive properties to the same cohesive layer. So I created 6 cohesive sections by partition. 3 sections have one cohesive property and the other 3 section have the second cohesive property. I have assigned sections through Abaqus/CAE. During the data check itself the job terminates with an error
*CONFLICT for the second cohesive material property. In the input file the Conflict block is for the second cohesive material property only. The data file error is
Keyword *Conflicts is generated by Abaqus/CAE to highlight
changes made via the Keywords Editor that conflict with changes made
subsequently via the native GUI.
I tried assigning manually in the .inp file as well but it did not work. I am wondering if it is possible to model different cohesive sections for the same cohesive layer. I have spent quite some time in modeling cohesive layers so my understanding with cohesive properties is quite good. Your help is really appreciated.
Thank you
Swapnil
Thank you
Swapnil
