Jack-and-bore is used for horizontal pipe installations (beneath highways, rivers, etc.) where a push and a receiving pit are excavated. Contractor installs what looks like a small locomotive on rails with a rotating head to auger and push a casing pipe through the ground to the receiving pit. Then pipe is pushed through the casing.
In microtunneling, pits are not always needed and the contractor can steer the cutting head horizontally and vertically to the receiving location. Many times they overbore the hole and use bentonite drilling mud, then when they pull the head back through the hole they drag the new pipe with a cable. Plastic pipe is popular for this, but iron pipe can also be accomodated. If iron pipe is used, it should be polywrapped.
Microtunneling would be preferred over jack-and-bore in areas of high water table unless the push and receiving pits have pumps running to draw down the water level during the work to keep the pits safe for boring and assembling the pipe.
