israelkk;
In an industrial setting air at 700 bar would be such a hazard that I would not want to be in the same building with it. On top of that imagine someone who has never worked with any kind of air equipment or who may work on a 100 PSI system once a month or less, which is the way most of industry maintains air and hydraulic equipment, and then send them out to work on a 4,350 PSI air system.
That would be similar to sending your 12 year old to work on a 4,400 Volt electrical system and expect them to come back alive.
A local plant has over 2,400 HP of air compressor capacity. They also have a 750 PSI setup to leak test their product but that is a whole different operation in only one area of the plant.
Another customer I worked with used 10,000 PSI air to blast coal in underground coal mines. This was due to the fire hazards from dynamite or other explosives. I never saw it work but they claimed it gave a similar effect to blasting powder.
On air compressing it is very inefficient. I had not come across the figures Dan reported for hydraulics but the air figures are close.
Imagine an air compressor piston with a 10" stroke that takes in atmospheric air at sea level and actually was filled with 14.7 PSIA atmospheric pressure when it passed Bottom Dead Center(BDC). When the piston moves half wau back towards Top Dead Center pressure in the cylinder would be 29.4 PSIA. When it moves to within 2.5" of TDC pressure would be 58.8 PSIA and further movement to 1.25" from TDC would get it up to 117.6 PSIA (103.1 PSIG). From this point on their will be some movement of air into the receiver if it is below 100 PSIG so that means the compressor is not moving much air into the system for each stroke it makes. If the system was operating at 150 PSIG you can see it would even be sending less air into the receiver.
If this same piston was full of Liquid instead of Gas it would move fluid from BDC to TDC and be a lot more efficient.
Does that give you an idea of why compressing air is so inefficient.
The 10,000 PSI air comressor I mentioned before actually had 7 pistons in stages. Air from the first piston was portd to the next smaller one and so on until the final 5/8" diameter piston pushed some air out at 10,000 PSIG.
Air is an expensive way to transmit energy. Notice how many persons have tried to use compressed air to drive automobiles. To date I have not come across any on the highways though it would be a very non-polluting way to get around if you didn't count the amount of coal you had to burn at the power plant to produce the energy at such a low efficiency.
Bud Trinkel CFPE
HYDRA-PNEU CONSULTING, INC.
fluidpower1 @ hotmail.com
