Difference between AFLAS O-RING and BUNA O-RING
pooyishka
Petroleum
Can we substitue AFLAS O-Ring with BUNA O-Ring?
I'll say "probably not, but maybe." Depends entirely on the fluid, pressure, and temperature.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Ok, thank you very much for your help. What is the usage for BUNA O-Ring?
"What is the usage for BUNA O-Ring?"
Cheap stuff that you don't mind having leak past the o-ring.
More seriously, google "Parker O-ring Handbook", download it, read it, and become an o-ring expert very quickly.
The industry trend in my area of interest (upstream oil and gas) is to specify the Aflas in moderately sour service and / or in amine service. Buna does not last as long or perform as well in those services, apparently.
There is a world of difference in the materials, Aflas being a Fluoropolymer and Buna-N being a Nitrile Rubber. Though both have their limitations the Aflas covers more ground, though at a higher cost.
A key point is if you are able, is to check it out in the fluid you are going to exposed to. A simple immersion test will tell you a lot as most charts are for pure materials.
