keerthivasan81
Chemical
I am in the process of deciding the AOD pump specification for charging a liquid from a 200 lit barrel to a 7500 lit vessel. The feed port on the vessel is at a height of 4 m from floor level. The liquid is viscous (viscosity: 6500 cp) in nature and pipeline size employed for transfer is 1.5” (discharge side) 2” (suction side) with discharge pipeline length around 7 m.
The pump was mounted at a height of 1.5 m from the floor level. The pump which I have selected gives a much lower flow rate (5 PLM immediately after pump discharge side itself at an air pressure of 6 ksc) which is far lower than my desired charging rate of 20 LPM.
Selected AOD pump details:
Max. Flow rate: 133 LPM; Max head: 85 m (in terms of water)
Diaphragm and ball valve MOC: PTFE
Max air pressure: 8 Ksc.
Feed and discharge port size: 1”.
As per the characteristic curve provided by the manufacturer, the pump delivers around 90 LPM at head of 20 m. I am obtaining only 5LPM immediately after the pump and my dynamic suction head will be around max 10 m
I know that viscosity of the actual fluid employed will reduce the flow rate. But the pump discharge flow rate is less than 10 % of the rated flow rate. I am surprised at the extent of pump flow rate reduction. My questions are:
1. What could be the reason for the very low flow rate obtained?.
2. Will Teflon diaphragm employed and suction lift (presently 1.5 m static) affect the pump discharge flow rate?
3. Any suggestion on selecting a pump of higher order or using the existing pump with any changes
