In a storm surge, the sea rises, and flows up the street to your house. The inflow rate will be determined by how high the water reaches above the basement windows, and the area of the window openings. The water pressure will automatically remove the glazing from the windows, so no worries there. You have zero hope of pumping it out as fast as it comes in.
After the ocean recedes, and you have cleared the wreckage of your neighbors' houses from around your own, you might wish to dewater the basement, which will be ... full of water. I hope you bought a fully submersible electric pump and that your emergency power source survives the storm.
Oh. The water will be full of trash, so a centrifugal pump will clog every few minutes, and you will have to haul it out, disassemble it, clean it, reassemble it, and drop it in again, and repeat ad nauseam.
Given all that, you might wish to instead invest in an engine powered diaphragm style dewatering pump. You leave it outside, snake the semirigid suction hose into the basement, start 'er up and keep adding fuel until she's burped out the contents of the basement onto your lawn.
When the water level gets low enough, you can put the pump in the basement on a makeshift raft to reduce the suction head while it gets the last few thousand gallons out. You won't be living in the house, and the basement windows are gone, so ventilation of the exhaust is not a big problem.
Mike Halloran
Pembroke Pines, FL, USA
