ajack1,
As I noted above, I would prefer that things are modeled to the nominal dimension. You process works fine for me.
As I also noted above, if I am going to fabricate your part or design a mating part, I have to learn your tolerances. I must carefully examine your drawing, and compare the tolerance text with the text on my drawing. It would be more convenient if each of us followed a standard, predictable procedure, but if you are outside my organization, I cannot make assumptions.
Here is another limitation of CAD. In the FN2 fit I described above, the MMC sizes, the median sizes and even the LMC sizes interfere. If I use any of these sizes in SolidWorks, I am not going to see the seam in my isometric drawing views. If both features are nominal, SolidWorks works fine.
What about nominal dimensions like 19.05mm?
JHG
