Hi All,
For automatic control valve sizing, I need to determine the inlet and the outlet pressure. The setup is as follows:
From the main reservoir, water is pumped through a centrifugal pump to another vessel. In between the centrifugal pump and the vessel there is a valve that can be used to manually regulate the flow rate. My intention is to replace the manual valve with an automatic flow control valve and therefore need to determine the inlet and outlet pressure at the control valve. Could anyone please tell me how to do that?
P.S. Please also see the drawing of the setup attached for more clarity.
