SCTrojan09
- Jan 26, 2010
- 8
I'm looking into developing the drivetrain for a cart which will be battery powered and travel at low speeds (around 0.33 m/s) along metal guide rails using v-groove wheels and weighing in around 4,000 kg. I'm trying to determine the necessary electric motor size to power the cart but my calcs just seem low. Am I missing something?
It looks like to accelerate at 0.1m/s^2 requires 12Nm of torque using a 60mm diameter wheel. (F=ma for a force of 400N times the 0.03m radius) This appears to work out to 3 hp when using an 1800 rpm electric motor. The rolling resistance appears to be 196N using a rolling resistance coefficient of 0.005. That works out to 0.09 hp using the 0.33 m/s. Summing that up comes to 3.1 hp, which even with a transmission efficiency of 80% is still only 4hp. Can I really get away with a 4 hp motor? I realize I will add on an additional fudge factor but it still seems low.
