Hello there.
First post, just new to the forum. Was hoping someone could help out.
I have ran a modal analysis on a plane model in FEMAP, and also carried out experimental work to determine the mode shapes. I then ran the analysis in Abaqus 6.7-1 as I prefer it, and I know how to have more control over meshing. The problem I get is, the mode shapes correspond with FEMAP and my experimental work.
However the frequency is giving in cycles/time. I know cycles/second = Hz. What correlation does the cycles/time give? As the values output do not match either my FEMAP or experimental expectations. I have looked in the INP file but I cannot find any time to calculate it from.
Hoping someone can shed some light on how to convert from this cycles/time into Hz.
Jonathan
Jonathan
